Scene Director
  • 1.  Scene Director
    Posted 03-14-2025 11:53
      |   view attached
    Hi everyone,
    I have attached my project and would appreciate any help. My scene director has an event at the end that is supposed to restart the playback from the beginning, but it isn't working.
    Can anyone help me figure out what I might be missing? It should play the slides and then start over again at the end. Thank you!
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
    Attachment(s)
    xpf
    COMMISH SLIDES TEST.xpf   889 KB 1 version
  • 2.  RE: Scene Director
    Posted 03-14-2025 12:06
    For me the restart works, what happens for you?
  • 3.  RE: Scene Director
    Posted 03-14-2025 12:59
    When i click on the sequence to go on AIR... It plays fine until the end, and stops on the last commissioner slide. it doesn't go back to the beginning.
    When i open up scene director to check it...it plays fine and goes back to the beginning.
    thank you
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 4.  RE: Scene Director
    Posted 03-14-2025 15:59
      |   view attached
    i added a video.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
    Note : Recently uploaded media files are still processing:
    • IMG_0616.MOV
  • 5.  RE: Scene Director
    Posted 03-17-2025 05:24
    I downloaded your scene and I play it out on my system and it restarts as you would expect. I did move the restart earlier in the timeline for testing purposes, have you tried that.
  • 6.  RE: Scene Director
    Posted 03-17-2025 06:30
    i tried it again and it played just fine.  Then I played it 5 minutes later and it got stuck again. It would t go back to the beginning.  Maybe it's our system?
  • 7.  RE: Scene Director
    Posted 03-17-2025 06:39
    What is the performance meter of your system saying when the graphic is playing?
  • 8.  RE: Scene Director
    Posted 03-17-2025 08:45
    It fluctuates from 29 to 31 percent.  The scene director is playing correctly now.  Later, who knows what it's going to do.
  • 9.  RE: Scene Director
    Posted 03-17-2025 08:54
    That's a good level of performance, pretty low actually so it's not that.
    This is just a thought but try putting a another reset 1 or 2 frames after the current one as a safety just incase the other one is being jumped for some reason as a work around for now.
  • 10.  RE: Scene Director
    Posted 03-17-2025 13:05
    It's not working again. I did what you told me to do and nothing. Can the file be corrupt?
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 11.  RE: Scene Director
    Posted 03-17-2025 13:06
    Make yourself a simple test scene to check if its a problem with the scene and or project.
  • 12.  RE: Scene Director
    Posted 03-17-2025 13:10
    I see you have a script on online to play the scene director, why is that? default will play anyway, is that perhaps messing with your scene?
  • 13.  RE: Scene Director
    Posted 03-17-2025 13:44
    Roman, helped me with that script. I did that because it wasn't dissolving when I took it online. I had a transition logic applied, but I removed it and used the script instead. Now it dissolves like I wanted. Let me try it without the script again to see the results.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 14.  RE: Scene Director
    Posted 03-17-2025 15:10
    I took out the script and nothing.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 15.  RE: Scene Director
    Posted 03-17-2025 15:22
    What do you mean by nothing?
  • 16.  RE: Scene Director
    Posted 03-17-2025 15:27
    Im. sorry.  It does the same thing.  It plays until the last slides and stops.  It does not go back to the beginning. Our engineer said he is going to take a look at the RAM. Is there a way to clear clean out memory or cache files.
  • 17.  RE: Scene Director
    Posted 03-17-2025 15:34
    What version are you on?
  • 18.  RE: Scene Director
    Posted 03-17-2025 15:38
    I played the file now and it's working. But later it might not.  I don't get it. Version 8.5. We are upgrading in 3 months or so to version 12.
  • 19.  RE: Scene Director
    Posted 03-17-2025 16:05
    When you say played the file what do you mean?
  • 20.  RE: Scene Director
    Posted 03-17-2025 16:08
    I mean when I click on it on the sequence side it plays
  • 21.  RE: Scene Director
    Posted 03-17-2025 16:20
    Cool, np I wanted to be sure.
    So yes for me it works every time.
    You could open a ticket with our tech support to check your machine.
  • 22.  RE: Scene Director
    Posted 03-17-2025 16:23
    Thanks for all your help. I will do that.
  • 23.  RE: Scene Director
    Posted 03-18-2025 21:49
    This is not a hardware issue, do not modify the hardware trying to solve this issue. It is a software or script or operational issue.
