Thank you, but that's not what I mean. I need to manually select a defined tactical formation in 3 lines: line 1: 1-5 players, line 2: 1-5 players, line 3: 1-5 players, where the sorting will be from left to right in order of 1 to 10 players. The number of players in a line should be defined so that I can choose in 3 fields of the excel file, e.g.: A1 - 3, A2 - 4, A3 - 3.
Tom Jan
editor
Sent: 09-24-2024 16:52
Subject: sorting tactical settings football/xpression/visual logic
I believe Roman had a solution. I've seen this referenced in a similar post.
https://rossvideo.community/viewdocument/re-racing-results-leaderboard-an?CommunityKey=91812bfd-9393-4a3f-8a74-7f8035df130e&tab=librarydocuments
Azathoth
Son of Cthulhu
Sent: 09-24-2024 16:40
Hi. Is there a good way to manage a soccer team's tactical setup, e.g. 4-4-2, 4-3-3, 5-3-2 etc. using visual logic and datatlinq? I want to manage the positioning of 10 quad objects (11 is the goalkeeper and will always be in the same position). There are always 3 lines of field players. Each can contain 1 to 5 players. The sorting of numbers should always be from left to right in order 1 to 10. I am using xpression version 9.5. I am not good at scripting. Is there a way to edit the tactical setup in the mother scene so that the changes are visible in various other scenes? Thanks in advance for your suggestions.
Tom Jan
editor
