  • 1.  Special Character - @ # $ % justifiction
    Posted 03-18-2025 01:22
    what will be the solution Special Character - @ # $ % justification. the scene is when you type any special character at the end of any text it will jump to Start- like -Start.
    when we start any additional word, it will return to its original justification.
    Is there any solution for this? I have checked the regional setting and default setting as well. I am using version 10.0 build 5250.
    [Wajahat] [Ali]
    [Team Lead] [RTG Designer]
    [Hum News][Capital-Islamabad] [Pakistan]
  • 2.  RE: Special Character - @ # $ % justifiction
    Posted 03-18-2025 05:34
    I hope you don't mind but I am going to explain it a little clearer here as you used different special characters in your example which is a little confusing for me, that may just be me getting confused but I thought to explain it with some pictures.
    I don't have a solution but @Garner Millward or @Patrick Twomey might.
    When you have right to left justification
    and you type here in the object inspector
    and then use special character it jumps to the start
    then if you continue typing it jumps back
  • 3.  RE: Special Character - @ # $ % justifiction
    Posted 03-18-2025 08:37
    I don't mind buddy. I actually don't have a mind lol hahaha......
    anyhow as you described it works when we uncheck the right-to-left text layout. cheers
    [Wajahat] [Ali]
