Thanks. I do have 11.5, trying to see if I can figure out the String Match because I definitely prefer streamlined!
EDIT- Got it working thusly. Too big to fit in the image, but you can see the idea:
Jake Lew
Access Communications Co-Operative Limited
Regina Canada
Sent: 09-26-2024 07:12
Subject: Standings Team Highlights
Jake,
This will get a little messier with more teams to highlight, but you could try something like this.
If you're working in XPression Version 11.5, you can streamline the logic a bit by using String Match blocks instead of String Value and Compare combos.
Jeff Mayer
Sent: 09-25-2024 16:56
I am trying to make our standings graphic so that we can select two teams to highlight, who will then receive an outline around their line/group.
How I have it is from Dashboard there are two numbers, one saying that for example team 1 should be highlighted and then another saying team 4 should be highlighted.
I have it half working. The issue I am running into is my one visual logic block cancels out the next visual logic block so that I can only seem to get one highlighted at a time. Any ideas? I am running out of them. What I am currently trying is below:
Jake Lew
Regina Canada
