Sent: 10-15-2024 14:35
Subject: Struct Array Table to dropdown
I took a brief look... I used this code to populate your number and name dropdowns:
var number;var numberArray = new Array();var name;var nameArray = new Array();var length = params.getElementCount('params.teamList');length = length -1;for (var i=0;i<=length;i++){ number = params.getValue('params.teamList.' + i +'.TeamNumber', 0); name = params.getValue('params.teamList.' + i +'.TeamName', 0); if (number != "") { ogscript.debug('Adding Dropdown Number: ' + number); ogscript.debug('Adding Dropdown Name: ' + name); numberArray[numberArray.length] = number; nameArray[nameArray.length] = name; }}params.replaceConstraint('NumberDropdown', params.createIntChoiceConstraint(numberArray));params.replaceConstraint('PlayerDropdown', params.createIntChoiceConstraint(nameArray));
However.... what I did find is that even with this code, if I had it on the prompt button, it would only populate the first row as you said. When I put the code on just a normal button it seems to work fine. Why the prompt button seems to only limit it to doing one row, I don't know!
Jake Lew
Access Communications Co-Operative Limited
Regina Canada
Sent: 10-11-2024 05:23
Trying to push data from a table to a dropdown box.
I am able to get the first row to populate but not the rest.
Any ideas?
<abs contexttype="opengear" dblinqport="2222" gridsize="20" keepalive="true"> <meta> <lookup id="hosts"> <entry key="local.port">7788</entry> <entry key="local.host">localhost</entry> </lookup> <params> <param access="1" constrainttype="STRUCT" name="Team Info" oid="templates.teamInfo" structtype="com.rossvideo.playinfo" type="STRUCT" widget="table"> <value> <subparam access="1" maxlength="0" name="Name" suboid="TeamName" type="STRING" value="Test" widget="default"/> <subparam access="1" maxlength="0" name="Number" suboid="TeamNumber" type="STRING" value="Test" widget="default"/> <subparam access="1" maxlength="0" name="Country" suboid="TeamCountry" type="STRING" value="Test" widget="default"/> <subparam access="1" maxlength="0" name="Finish Time" suboid="TeamFinish" type="STRING" value="Test" widget="default"/> <subparam access="1" maxlength="0" name="Split 1" suboid="TeamSplit1" type="STRING" value="Test" widget="default"/> <subparam access="1" maxlength="0" name="Split 2" suboid="TeamSplit2" type="STRING" value="Test" widget="default"/> <subparam access="1" maxlength="0" name="Split 3" suboid="TeamSplit3" type="STRING" value="Test" widget="default"/> <subparam access="1" maxlength="0" name="Split 4" suboid="TeamSplit4" type="STRING" value="Test" widget="default"/> </value> </param> <param access="1" maxlength="0" name="runClock" oid="runClock" type="STRING" value="00:00.000" widget="label"/> <param access="1" constrainttype="INT_CHOICE" name="Confirm Prompt" oid="Confirm_Prompt" precision="0" type="INT32" value="1" widget="button-prompt"> <config key="w.changeprompt">Submit changes?</config> <constraint key="0">Submit</constraint> <constraint key="1">Submit</constraint> </param> <param access="1" maxlength="0" name="rowstyles" oid="rowstyles" type="STRING" value="bg#000011;fg#ffffff" widget="default"/> <param access="1" constrainttype="STRUCT" name="Team Info" oid="params.teamList" structtype="com.rossvideo.teaminfo" templateoid="templates.teamInfo" type="STRUCT_ARRAY" widget="table"> <value> <subparam suboid="TeamName" value="Name 1"/> <subparam suboid="TeamNumber" value="1"/> <subparam suboid="TeamCountry" value="GBR"/> <subparam suboid="TeamFinish" value="1:02.124"/> <subparam suboid="TeamSplit1" value="+1:56.125"/> <subparam suboid="TeamSplit2" value=""/> <subparam suboid="TeamSplit3" value=""/> <subparam suboid="TeamSplit4" value=""/> </value> <value> <subparam suboid="TeamName" value="Name 2"/> <subparam suboid="TeamNumber" value="2"/> <subparam suboid="TeamCountry" value="IRL"/> <subparam suboid="TeamFinish" value="1:07.321"/> <subparam suboid="TeamSplit1" value="72\"/> <subparam suboid="TeamSplit2" value=""/> <subparam suboid="TeamSplit3" value=""/> <subparam suboid="TeamSplit4" value=""/> </value> <value> <subparam suboid="TeamName" value="Name 3"/> <subparam suboid="TeamNumber" value="3"/> <subparam suboid="TeamCountry" value="GBR"/> <subparam suboid="TeamFinish" value="1:06.256"/> <subparam suboid="TeamSplit1" value=""/> <subparam suboid="TeamSplit2" value=""/> <subparam suboid="TeamSplit3" value=""/> <subparam suboid="TeamSplit4" value=""/> </value> <value> <subparam suboid="TeamName" value="Name 4"/> <subparam suboid="TeamNumber" value="4"/> <subparam suboid="TeamCountry" value="FRA"/> <subparam suboid="TeamFinish" value="59.231"/> <subparam suboid="TeamSplit1" value=""/> <subparam suboid="TeamSplit2" value=""/> <subparam suboid="TeamSplit3" value=""/> <subparam suboid="TeamSplit4" value=""/> </value> <value> <subparam suboid="TeamName" value="Name 5"/> <subparam suboid="TeamNumber" value="5"/> <subparam suboid="TeamCountry" value="AUS"/> <subparam suboid="TeamFinish" value=""/> <subparam suboid="TeamSplit1" value=""/> <subparam suboid="TeamSplit2" value=""/> <subparam suboid="TeamSplit3" value=""/> <subparam suboid="TeamSplit4" value=""/> </value> <value> <subparam suboid="TeamName" value=""/> <subparam suboid="TeamNumber" value=""/> <subparam suboid="TeamCountry" value=""/> <subparam suboid="TeamFinish" value=""/> <subparam suboid="TeamSplit1" value=""/> <subparam suboid="TeamSplit2" value=""/> <subparam suboid="TeamSplit3" value=""/> <subparam suboid="TeamSplit4" value=""/> </value> </param> <param access="1" constrainttype="INT_CHOICE" name="NumberDropdown" oid="NumberDropdown" precision="0" type="INT16" value="0" widget="default"> <constraint key="0">3</constraint> </param> <param access="1" constrainttype="INT_CHOICE" name="PlayerDropdown" oid="PlayerDropdown" precision="0" type="INT16" value="0" widget="default"> <constraint key="0">Name 3</constraint> </param> <param access="1" constrainttype="INT_CHOICE" name="CountryDropdown" oid="CountryDropdown" precision="0" type="INT16" value="0" widget="default"> <constraint key="0">GBR</constraint> </param> <param access="1" constrainttype="INT_CHOICE" name="FinishDropdown" oid="FinishDropdown" precision="0" type="INT16" value="0" widget="default"> <constraint key="0">1:01.321</constraint> </param> <param access="1" constraint="0.0;100.0;0.0;100.0;1" constrainttype="INT_STEP_RANGE" name="Selection" oid="Selection" precision="0" type="INT32" value="4" widget="default"/> <param access="1" constrainttype="INT_CHOICE" name="Dropdown" oid="params.combo" precision="0" type="INT16" value="0" widget="combo"> <constraint key="0">a</constraint> <constraint key="1">b</constraint> <constraint key="2">c</constraint> <constraint key="3">d</constraint> </param> <param access="1" constrainttype="STRING_CHOICE" name="Table" oid="params.table" precision="0" type="INT16" value="0" widget="table"> <constraint>params.array</constraint> </param> <param access="1" constrainttype="INT_CHOICE" name="Split1Dropdown" oid="Split1Dropdown" precision="0" type="INT16" value="0" widget="default"> <constraint key="0">1:01.321</constraint> </param> </params> </meta> <table colspan="1" fill="both" height="540" insets="2,2,2,10" left="60" rowspan="1" style="bg#dark;bdr:round;" top="60" weightx="1.0" weighty="1.0" width="1000"> <tr> <label colspan="2" fill="both" insets="2,2,2,2" name="Competitiors" rowspan="1" style="txt-align:west;font:bold;size:Big;" weightx="1.0" weighty="0.0"/> </tr> <tr> <param colspan="7" constrainttype="STRING_CHOICE" element="0" evenstyle="f:bg#tablezebra;" fill="both" insets="2,2,2,2" oid="params.teamList" precision="0" rowspan="1" showlabel="false" style="t:bg#696969;" weightx="1.0" weighty="1.0"> <config key="w.selectionparam">Selection</config> <config key="w.reorder">true</config> <config key="w.padding">10,15</config> <config key="w.colminwidth.0">250</config> <constraint>TeamName</constraint> <constraint>TeamNumber</constraint> <constraint>TeamFinish</constraint> <constraint>TeamCountry</constraint> <constraint>TeamSplit1</constraint> <constraint>TeamSplit2</constraint> <constraint>TeamSplit3</constraint> <constraint>TeamSplit4</constraint> </param> </tr> </table> <param expand="true" height="60" left="1220" oid="PlayerDropdown" precision="0" showlabel="false" style="size:Biggest;bdr:round;" top="180" widget="combo" width="260"> <task tasktype="ogscript">// Set the number to matchvar player = params.getValue('PlayerDropdown', 0);var number = params.getValue('NumberDropdown',0);var country = params.getValue('CountryDropdown',0);var finish = params.getValue('FinishDropdown',0);if (player != number) { ogscript.debug('Player dropdown value, doing change to:' + player); params.setValue('NumberDropdown', 0, player); }else ogscript.debug('Player dropdown value, No Change:' + player); if (player != country) { ogscript.debug('Player dropdown value, doing change to:' + player); params.setValue('CountryDropdown', 0, player); }else ogscript.debug('Player dropdown value, No Change:' + player);if (finish != country) { ogscript.debug('Number dropdown value, doing change to:' + player); params.setValue('FinishDropdown', 0, number); }else ogscript.debug('Number dropdown value, No change to:' + number);</task> </param> <param expand="true" height="60" left="1120" oid="NumberDropdown" precision="0" showlabel="false" style="bdr:round;" top="180" widget="combo" width="80"> <task tasktype="ogscript">// Set the number to matchvar player = params.getValue('PlayerDropdown', 0);var number = params.getValue('NumberDropdown',0);var country = params.getValue ('CountryDropdown',0);var finish = params.getValue ('FinishDropdown',0);if (player != number) { ogscript.debug('Number dropdown value, doing change to:' + player); params.setValue('PlayerDropdown', 0, number); }else ogscript.debug('Number dropdown value, No change to:' + number); if (country != number) { ogscript.debug('Number dropdown value, doing change to:' + player); params.setValue('CountryDropdown', 0, number); }else ogscript.debug('Number dropdown value, No change to:' + number);if (finish != number) { ogscript.debug('Number dropdown value, doing change to:' + player); params.setValue('FinishDropdown', 0, number); }else ogscript.debug('Number dropdown value, No change to:' + number);</task> </param> <param expand="true" height="40" left="1120" oid="CountryDropdown" style="bg#textbg;" top="260" widget="label" width="120"/> <param expand="true" height="40" left="1260" oid="FinishDropdown" style="bg#textbg;" top="260" widget="label" width="140"> <task tasktype="ogscript"/> </param> <param colspan="2" expand="true" fill="both" height="60" insets="2,2,2,2" left="1320" oid="Confirm_Prompt" rowspan="1" style="style:toggleButton;bg#001FC1;size:Big;font:bold;txt-align:center;" top="100" width="180"> <task tasktype="ogscript"/> <task tasktype="ogscript">var i; // loop counterfor (i=0;i<30;i++) // Hardcoded to 30 elements in the player names{ Name = params.getValue('params.teamList.TeamName', i); Number = params.getValue('params.teamList.TeamNumber',i); Country = params.getValue('params.teamList.TeamCountry',i); Finish = params.getValue('params.teamList.TeamFinish',i); Split1 = params.getValue('params.teamList.TeamSplit1',i);}// Now update the constraintparams.replaceConstraint('PlayerDropdown', constraintName);params.replaceConstraint('NumberDropdown', constraintNumber);params.replaceConstraint('CountryDropdown', constraintCountry);params.replaceConstraint('FinishDropdown', constraintFinish);params.replaceConstraint('Split1Dropdown', constraintSplit1);ogscript.debug('Starting to Create Dropdowns');//var Names = new Array();var Numbers = new Array();var Country = new Array();var Finish = new Array();var Split1 = new Array();var i; // loop countervar name; // Temp name valuevar number; // Temp number valuevar country; // Temp country valuevar finish; // Temp finish valuevar split1; // Temp split1 value// Namesfor (i=0;i<30;i++) // Hardcoded to 30 elements in the player names{ name = params.getValue('params.teamList.TeamName', i); number = params.getValue('params.teamList.TeamNumber',i); country = params.getValue('params.teamList.TeamCountry',i); finish = params.getValue('params.teamList.TeamFinish',i); split1 = params.getValue('params.teamList.TeamSplit1',i); ogscript.debug('Found Player: ' + name + ' Jersey: ' + number); // Skip this one if the value is the default value if (name != 'Insert Name') { ogscript.debug('Adding Entry: ' + name); Names[Names.length] = name; Numbers[Numbers.length] = number; Country[Country.length] =country; Finish[Finish.length] =finish; Split1[Split1.length] =split1; }}// Now update the constraintparams.replaceConstraint('NumberDropdown', params.createIntChoiceConstraint(Numbers));params.replaceConstraint('PlayerDropdown', params.createIntChoiceConstraint(Names));params.replaceConstraint('CountryDropdown', params.createIntChoiceConstraint(Country));params.replaceConstraint('FinishDropdown', params.createIntChoiceConstraint(Finish));params.replaceConstraint('Split1Dropdown', params.createIntChoiceConstraint(Split1));ogscript.debug('Names.length:' + Names.length);</task> </param> <param colspan="2" expand="true" fill="both" height="60" insets="2,2,2,2" left="1120" oid="Confirm_Prompt" rowspan="1" style="style:toggleButton;bg#001FC1;size:Big;font:bold;txt-align:center;" top="100" width="180"> <task tasktype="ogscript"/> <task tasktype="ogscript">var newValuesName = params.getAllValues('params.teamList.TeamName');var constraintName = params.createIntChoiceConstraint(newValuesName);var newValuesNumber = params.getAllValues('params.teamList.TeamNumber');var constraintNumber = params.createIntChoiceConstraint(newValuesNumber);var newValuesCountry = params.getAllValues('params.teamList.TeamCountry');var constraintCountry = params.createIntChoiceConstraint(newValuesCountry);var newValuesFinish = params.getAllValues('params.teamList.TeamFinish');var constraintFinish = params.createIntChoiceConstraint(newValuesFinish);var newValuesSplit1 = params.getAllValues('params.teamList.TeamSplit1');var constraintSplit1 = params.createIntChoiceConstraint(newValuesSplit1);params.replaceConstraint('PlayerDropdown', constraintName);params.replaceConstraint('NumberDropdown', constraintNumber);params.replaceConstraint('CountryDropdown', constraintCountry);params.replaceConstraint('FinishDropdown', constraintFinish);params.replaceConstraint('Split1Dropdown', constraintSplit1);</task> </param> <param expand="true" height="40" left="1420" oid="Split1Dropdown" style="bg#textbg;" top="260" widget="label" width="140"> <task tasktype="ogscript"/> </param></abs>
Sam McIntosh
National Rugby League
Australia
