  • 1.  Table navigation with add/delete row function
    Posted 09-30-2024 06:00
    Hi I have tried to build a table using code from example panels but am unable to get it working.
    Essentialy I would like a button to add rows and one to delete rows with up and down arrows to navigate the table.
    If someone can assist with what I have wrong that'd be great. Thanks
       <meta>
          <params>
             <param access="1" maxlength="0" name="Rider Name" oid="riderName" precision="0" type="STRING_ARRAY" widget="default">
                <value>Name 1</value>
                <value>Name 2</value>
                <value>Name 3</value>
                <value>Name 4</value>
                <value>Name 5</value>
             </param>
             <param access="1" maxlength="0" name="Rider Number" oid="riderNumber" precision="0" type="STRING_ARRAY" widget="default">
                <value>1</value>
                <value>2</value>
                <value>3</value>
                <value>4</value>
                <value>5</value>
             </param>
             <param access="1" maxlength="0" name="Country" oid="riderCountry" precision="0" type="STRING_ARRAY" widget="default">
                <value>CAN</value>
                <value>GBR</value>
                <value>GBR</value>
                <value>AUS</value>
                <value>USA</value>
             </param>
             <param access="1" maxlength="0" name="Final Time" oid="riderFinalTime" precision="0" type="STRING_ARRAY" widget="default">
                <value/>
                <value/>
                <value/>
                <value/>
                <value/>
             </param>
             <param access="1" maxlength="0" name="Split 1" oid="riderSplit1" precision="0" type="STRING_ARRAY" widget="default">
                <value/>
                <value/>
                <value/>
                <value/>
                <value/>
             </param>
             <param access="1" maxlength="0" name="Split 2" oid="riderSplit2" precision="0" type="STRING_ARRAY" widget="default">
                <value/>
                <value/>
                <value/>
                <value/>
                <value/>
             </param>
             <param access="1" maxlength="0" name="Split 3" oid="riderSplit3" precision="0" type="STRING_ARRAY" widget="default">
                <value/>
                <value/>
                <value/>
                <value/>
                <value/>
             </param>
             <param access="1" maxlength="0" name="Split 4" oid="riderSplit4" precision="0" type="STRING_ARRAY" widget="default">
                <value/>
                <value/>
                <value/>
                <value/>
                <value/>
             </param>
             <param access="1" constrainttype="STRING_CHOICE" name="params.table" oid="params.table" precision="0" type="INT32" value="0" widget="table">
                <config key="w.selectionparam">Selection</config>
                <constraint>riderName</constraint>
                <constraint>riderNumber</constraint>
                <constraint>riderCountry</constraint>
                <constraint>riderFinalTime</constraint>
                <constraint>riderSplit1</constraint>
                <constraint>riderSplit2</constraint>
                <constraint>riderSplit3</constraint>
                <constraint>riderSplit4</constraint>
             </param>
             <param access="1" constrainttype="INT_NULL" name="Selection" oid="Selection" precision="0" type="INT32" value="4" widget="label"/>
          </params>
          <api>function moveUp()
    move(-1);
    function moveDown()
    move(1);
    function move(direction)
    var selection = params.getValue('params.table', 0);
    var newSelection = selection + direction;
    if (newSelection &lt; 0 || newSelection &gt; params.getElementCount('riderName'))
    return; //If we are moving up but are already at the top or moving down and are already at the bottom
    var newValues = [];
    var oldValues = params.getAllValues('riderName');
    for (var i = 0; i &lt; oldValues.length; i++)
    if (direction &gt; 0 &amp;&amp; i != selection) //If we are down, add the value already at index first
    newValues.push(oldValues[i]);
    if (i == newSelection)
    newValues.push(oldValues[selection]);
    if (direction &lt; 0 &amp;&amp; i != selection) //If we are up, add the value already at index after
    params.setAllValues('riderName', newValues);
    params.setValue('params.table', 0, newSelection);
    }</api>
       </meta>
       <table colspan="1" fill="both" height="500" insets="2,2,2,10" left="142" rowspan="1" style="bg#dark;bdr:round;" top="159" weightx="1.0" weighty="1.0" width="1261">
          <tr>
             <label colspan="2" fill="both" height="50" insets="2,2,2,2" name="Competitiors" rowspan="1" style="txt-align:west;font:bold;size:Big;" weightx="1.0"/>
             <param expand="true" fill="both" insets="2,2,2,2" oid="Selection" style="bdr:etched;bg#dark;font:bold;size:Big;o#000000;fg#FFFFFF;txt-align:center;" weightx="0.0" weighty="0.0" widget="spinner"/>
             <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" name=" ▲ " rowspan="1" style="bg#lightdivider;size:16;font:bold;" weightx="0.0" weighty="0.0">
                <task tasktype="ogscript">moveUp();</task>
             </button>
             <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" name=" ▼ " rowspan="1" style="bg#lightdivider;size:16;font:bold;" weightx="0.0" weighty="0.0">
                <task tasktype="ogscript">moveDown();</task>
                <task tasktype="ogscript"/>
             </button>
             <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" name="Add Competitor +" rowspan="1" style="bg#23B126;size:16;font:bold;" weightx="0.15" weighty="0.0">
                <task tasktype="ogscript">var newValue = {
       riderName: "",
       riderNumber: "",
       riderCountry: "",
       riderFinalTime: "",
       riderSplit1: "",
       riderSplit2: "",
       riderSplit3: "",
       riderSplit4: ""
    var p = params.getParam('params.table', 0);
    p.setValueAt(p.getElementCount(), newValue);</task>
             </button>
             <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" name="Delete Competitor -" rowspan="1" style="bg#D41033;size:16;font:bold;" weightx="0.15" weighty="0.0">
                <task tasktype="ogscript">&lt;button buttontype="push" height="60" left="760" name="Delete Selected" top="380" width="120"&gt;
       &lt;task tasktype="ogscript"&gt;var selection = params.getValue('Selection', 0);
    if (selection &amp;lt; 0)
       return;
    var newValue = new Array();
    var table = params.getParam('params.table', 0);
    for (var i = 0; i &amp;lt; table.getElementCount(); i++)
       if (i != selection)
          newValue.push(table.getValueAt(i));
    params.setAllValues('params.table', newValue);&lt;/task&gt;
    &lt;/button&gt;</task>
             </button>
          </tr>
          <tr>
             <param colspan="7" expand="true" fill="both" insets="2,2,2,2" oid="params.table" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0">
                <config key="w.reorder">true</config>
             </param>
          </tr>
       </table>
    Sam McIntosh
    National Rugby League
    Australia
  • 2.  RE: Table navigation with add/delete row function
    Posted 10-02-2024 02:42
    Hi Sam,
    I've had a quick look at your table, and edited the button [ADD COMPETITOR +]
    and this now works.
    you need to create an iteration to create an array entry for each param,
    you can follow what I've done here and apply it to the other data buttons you need.
    hope this helps.
       <meta>
          <params>
             </param>
                <value>1</value>
                <value>2</value>
                <value>3</value>
                <value>4</value>
                <value>5</value>
             </param>
                <value>CAN</value>
                <value>GBR</value>
                <value>AUS</value>
                <value>USA</value>
                <value>AUS</value>
             </param>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
             </param>
                <value>1</value>
                <value>2</value>
                <value>3</value>
                <value>4</value>
                <value>5</value>
             </param>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
             </param>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
             </param>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
                <value>
                </value>
             </param>
             <param access="1" constrainttype="STRING_CHOICE" name="params.table" oid="params.table" precision="0" type="INT32" value="4" widget="table">
             </param>
             <param access="1" constrainttype="INT_NULL" name="Selection" oid="Selection" precision="0" type="INT32" value="1" widget="label"/>
          </params>
          <api>function moveUp() { move(-1); }
    function moveDown() { move(1); }
       var newSelection = selection + direction; if (newSelection &lt; 0 || newSelection &gt; params.getElementCount('riderName'))
       return; //If we are moving up but are already at the top or moving down and are already at the bottom } var newValues = []; var oldValues = params.getAllValues('riderName'); for (var i = 0; i &lt; oldValues.length; i++) { if (direction &gt; 0 &amp;&amp; i != selection) //If we are down, add the value already at index first { newValues.push(oldValues[i]); } if (i == newSelection) { newValues.push(oldValues[selection]); } if (direction &lt; 0 &amp;&amp; i != selection) //If we are up, add the value already at index after { newValues.push(oldValues[i]); } } params.setAllValues('riderName', newValues); params.setValue('params.table', 0, newSelection); }
    }</api>
       </meta>
       <table colspan="1" fill="both" height="750" insets="2,2,2,10" left="142" rowspan="1" style="bg#dark;bdr:round;" top="159" weightx="1.0" weighty="1.0" width="1261">
          <tr>
             </button>
             </button>
    //figure out how many cols (Params) need to be added
    var tableCols = params.getConstraint('params.table')
    var tableCols = tableCols.getChoices()
    // figure out how many array records are currently entered
    var tableRowCount = params.getElementCount('riderName');
    //append a new array entry at the end of the list
    for (var i = 0; i &lt; tableCols.length; i++)
       var p = params.getParam(tableCols[i], 0)
       p.setValueAt(tableRowCount, "")
    </task>
             </button>
                <task tasktype="ogscript">&lt;button buttontype="push" height="60" left="760" name="Delete Selected" top="380" width="120"&gt; &lt;task tasktype="ogscript"&gt;var selection = params.getValue('Selection', 0); if (selection &amp;lt; 0) { return; } var newValue = new Array(); var table = params.getParam('params.table', 0); for (var i = 0; i &amp;lt; table.getElementCount(); i++) { if (i != selection) { newValue.push(table.getValueAt(i)); } } params.setAllValues('params.table', newValue);&lt;/task&gt; &lt;/button&gt;</task>
             </button>
          </tr>
          <tr>
             </param>
          </tr>
       </table>
       <button buttontype="push" height="1" left="641" top="58" width="1"/>
    Thomas Wilson
    Project Manager / Engineer
    Innovative Production Services
    4K ONE OB Truck | SYDNEY
  • 3.  RE: Table navigation with add/delete row function
    Posted 10-11-2024 14:58
