Thanks again Jake, this is great.
Much appreciated
Sent: 06-12-2024 10:59
Subject: Table to populate data from dropdown menu
I also have that function in my project! Would go something like this:
//Set Dropdown Selectionvar length = params.getElementCount('params.teamnames');length = length -1;var nameArray = new Array();for (i=0;i<=length;i++){ var name = params.getValue('params.teamnames', i); nameArray[nameArray.length] = name;}params.replaceConstraint('xpression.selector1', params.createIntChoiceConstraint(nameArray));
Jake Lew
Access Communications Co-Operative Limited
Regina Canada
Sent: 06-11-2024 19:59
Great that works, thanks Jake!
It would be nice if the team names could be added to the dropdown automatically.
Sam McIntosh
National Rugby League
Australia
Sent: 06-07-2024 17:18
I do something similar to set team info from a table. Here's an adapted version. Your dropdown didn't have any teams in it, so I added the three teams to the dropdown and then I put this task onto the dropdown:
var SelectedTeam = params.getStrValue('xpression.selector1', 0);var length = params.getElementCount('params.teamnames');ogscript.debug("Found " + length + " teams in the table");length = length -1;for (var i=0;i<=length;i++){var TeamName = params.getValue('params.teamnames', i);if (SelectedTeam === TeamName){//Set Team Name params.setValue('xpression.teamnames', 0, TeamName); ogscript.debug("SETTING TEAM NAME: " + TeamName);//Set Short Name var ShortName = params.getValue('params.shortnames', i); params.setValue('xpression.shortnames', 0, ShortName); ogscript.debug("SETTING SHORT NAME: " + ShortName);//Set Established var Established = params.getValue('params.established', i); params.setValue('xpression.established', 0, Established); ogscript.debug("SETTING ESTABLISHED: " + Established);//Set Colour var Colour = params.getValue('params.colour', i); params.setValue('xpression.colour', 0, Colour); ogscript.debug("SETTING COLOUR: " + Colour);//Set Logo var Logo = params.getValue('params.logo', i); params.setValue('xpression.logo', 0, Logo); ogscript.debug("SETTING LOGO: " + Logo);}}
Jake Lew
Regina Canada
Sent: 06-06-2024 21:28
I have a simple table in dashboard which I would like to populate team values from the table once a team is selected from a dropdown menu.
What is the best way to do this?
<abs contexttype="opengear" id="_top" keepalive="false" style=""> <meta> <params> <param access="1" maxlength="0" name="Table Short Names" oid="params.shortnames" precision="0" type="STRING_ARRAY" widget="default"> <value>NEW</value> <value>SYD</value> <value>BRI</value> </param> <param access="1" constrainttype="STRING_CHOICE" name="Table" oid="params.table" precision="0" type="INT16" value="2" widget="table"> <constraint>params.teamnames</constraint> <constraint>params.shortnames</constraint> <constraint>params.established</constraint> <constraint>params.colour</constraint> <constraint>params.logo</constraint> </param> <param access="1" maxlength="0" name="Table Team Names" oid="params.teamnames" precision="0" type="STRING_ARRAY" widget="default"> <value>Newcastle</value> <value>Sydney</value> <value>Brisbane</value> </param> <param access="1" maxlength="0" name="Table Established" oid="params.established" precision="0" type="STRING_ARRAY" widget="default"> <value>1999</value> <value>2000</value> <value>2001</value> </param> <param access="1" constrainttype="INT_CHOICE" name="Xpression Selector 1" oid="xpression.selector1" precision="0" type="INT16_ARRAY" value="-1" widget="default"> <constraint key="-1">Select Team</constraint> <constraint key="0"/> </param> <param access="1" maxlength="0" name="Xpression Team Names" oid="xpression.teamnames" precision="0" type="STRING_ARRAY" widget="label"> <value>0</value> </param> <param access="1" maxlength="0" name="Xpression Short Names" oid="xpression.shortnames" precision="0" type="STRING_ARRAY" widget="label"> <value>0</value> </param> <param access="1" maxlength="0" name="Xpression Established" oid="xpression.established" precision="0" type="STRING_ARRAY" widget="label"> <value>0</value> </param> <param access="1" maxlength="0" name="Table Colour" oid="params.colour" precision="0" type="STRING_ARRAY" widget="default"> <value>#FF5733</value> <value>#FFFFFF</value> <value>#000000</value> </param> <param access="1" maxlength="0" name="Table Logo" oid="params.logo" precision="0" type="STRING_ARRAY" widget="default"> <value>https://www.nrl.com/.theme/knights/badge.svg?bust=202405130630</value> <value>https://www.nrl.com/.theme/broncos/badge.svg?bust=202405130630</value> <value>https://www.nrl.com/.theme/roosters/badge.svg?bust=202405130630</value> </param> <param access="1" maxlength="0" name="Xpression Colour" oid="xpression.colour" precision="0" type="STRING_ARRAY" widget="label"> <value>0</value> </param> <param access="1" maxlength="0" name="Xpression Logo" oid="xpression.logo" precision="0" type="STRING_ARRAY" widget="label"> <value>0</value> </param> </params> </meta> <abs height="671" left="9" top="7" width="1135"> <param expand="true" height="222" left="446" oid="params.table" showlabel="false" top="22" width="675"/> <table height="352" left="39" style="bg#dark;bdr:etched;" top="39" width="267"> <tr> <param colspan="2" expand="true" fill="both" insets="2,2,2,2" left="13" oid="xpression.selector1" rowspan="1" runtasksonload="true" showlabel="false" top="501" weightx="1.0" weighty="1.0"/> </tr> <tr> <label colspan="1" fill="both" insets="2,2,2,2" name="Name: " rowspan="1" style="txt-align:east" weightx="0.0" weighty="1.0"/> <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.teamnames" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/> </tr> <tr> <label colspan="1" fill="both" insets="2,2,2,2" name="Short Name: " rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/> <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.shortnames" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/> </tr> <tr> <label colspan="1" fill="both" insets="2,2,2,2" name="Established: " rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/> <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.established" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/> </tr> <tr> <label colspan="1" fill="both" insets="2,2,2,2" name="Colour:" rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/> <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.colour" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/> </tr> <tr> <label colspan="1" fill="both" insets="2,2,2,2" name="Logo:" rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/> <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.logo" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/> </tr> </table> </abs></abs>
Sam McIntosh
Australia
