  • 1.  TD2 4880AR
    Posted 08-14-2024 18:57
    Just checking on software versions. We have a TD2 with a part 4880AR - 212-02 (Intel Celeron CPU). The docs mention Intel Qseven as the CPU. So I'm wondering which version of the upgrade is for my panel.
    Also, will the panel accept a wrong version is an error is made?
    UPDATE: Tech Support let me know that I should use the Intel s/w version, even though it's a Celeron CPU, not Qseven. Also, I originally loaded the ADM version and the panel worked! How much it worked, well, I didn't bother to investigate.
    San Francisco United States
  • 2.  RE: TD2 4880AR
    Posted 08-15-2024 05:59
    It is an Intel Celeron on a Qseven Module.
    They  are like a socketed PC so that you don't have to build all new PCBs when a newer module or revision is released.
    The AMD upgrade would have never actually run.  After the upgrade uploaded the TD Panel would have checked that it is not the correct package and then would have just rebooted to the version it was running.
  • 3.  RE: TD2 4880AR
    Posted 08-15-2024 15:20
    Idiot proofing:)
