  • 1.  Turn on and off material colors to change text colors
    Posted 03-19-2025 13:10
    I am wondering if there is a way, either with keyframes or visual logic to change font colors in one scene. I am working on a lineup graphic that I want to highlight the first name yellow, then advance to the next name, making the next name yellow and the previous back to white. Any ideas? Thanks!
    Brian Contreras
    Production Coordinator
  • 2.  RE: Turn on and off material colors to change text colors
    Posted 03-19-2025 18:23
    Keep in mind; changing a font (or a material for that matter) will affect the usage of that asset project wide.
    A thought that might work for you; make a font that's a mask material, so it's poking through your lineup 'background', but then beneath that you have another white background and a yellow quad between the real lineup and the white that is your highlight. When your player changes, you move the yellow highlight.
    Zachary Fradette
    United States
  • 3.  RE: Turn on and off material colors to change text colors
    Posted 03-20-2025 06:36
      |   view attached
    Hello.
    Brian, you can use such parameter "{m:Yellow}" for text objects where "Yellow" is the name of the material in the scene.
    An example of how it will look like this
    Text1.Text = "{m:Yellow}" & Text1.Text (if this script is not assigned to the text object)
    Roman Yaroshenko
    chief specialist
    RBC-TV
    Moscow Russian Federation
    Attachment(s)
    xpf
    Test_Color.xpf   29 KB 1 version
  • 4.  RE: Turn on and off material colors to change text colors
    Posted 03-20-2025 10:02
    Azathoth
    Son of Cthulhu
  • 5.  RE: Turn on and off material colors to change text colors
    Posted 03-20-2025 21:53
    I assume you are aiming for something similar to the image below. I did this a while back, so there might be a more efficient way I would do it today, but all I did was two text object with the two colours I needed and keyframed their visibility based on where the highlight was
    Carlito Chippy
