I ran some tests with Companion 3.4.3 and Ultrix Version 6.2
I can confirm that the following rosstalk commands do the following on my stopwatch that is using ID 2
TIMER 02:RUN
Starts the Stopwatch from 00:00:00 and after being paused continues from the value where it was.
TIMER 02:PAUSE
Pauses the Stopwatch.
TIMER 02:STOP
Stops and Resets the Stopwatch.
Ill try again at V5.3.1 tomorrow.
Mike Pomerleau
Sent: 10-30-2024 12:59
Subject: Ultriscape Clocks control.
Hi Mike,
we are curently runing V 5.3.1 but I'm looking forward to upgrade to V6.2...
regards,
Boris
Boris salhaji
EIC
France Télévisions
Sent: 10-30-2024 11:34
Hi Boris,
Before I run some tests can you tell me which version of Ultrix you are using?
Mike Pomerleau
Sent: 10-29-2024 07:06
Hello everyone,
We use the clocks functionalities of Ultriscape to have Time of the day and a stopwatch.
we control it with a streamdeck and rosstalk.
We got an issue in Ultriscape dashboard panel we can pause the stopwatch and resume the count by using the play and pause buttons. But with the streamdeck the command Timer:pause is working but when we perform the command Timer:run the count start over returning to 00:00:00. Is that a normal behavior? is there a command to just pause and resume the count.
Best regards
Boris salhaji
EIC
France Télévisions
