Ok, got it. Thanks for the quick reply.
Paul Whitfield
Sent: 11-18-2023 22:52
Subject: Ultriscape Head outputs
Hi Paul,
Thanks for the question. The Multiviewer is applied at the output and is not natively available as a source. However you can re-enter the multiviewer with a HDBNC cable without any issues.
Hope this helps!
Mike Pomerleau
Sent: 11-18-2023 19:44
Does an Ultriscape head appear as a source on the router to be output to multiple destinations or does it only output from the physical connection designated with the license
Paul Whitfield
