Hey Mike,
Thanks for your prompt response (and apologies for my tardy one!).
That's very helpful. My Ultrix clock is currently synced to the local PC, while I hunt for an NTP IP address that Ultix will connect to.
Follow up question:
The rest of the clocks in the venue are synced to timecode from the SPG. The Ultrix and Carbonite receive their sync from the same source. Is it possible to sync the Ultrix clock to timecode?
On Wed, 14 Feb 2024 at 13:38, Mike Pomerleau via Ross Video Limited <
Mail@rossvideo.com> wrote:
You can set the internal clock of the ultrix to synchronise to NTP. this should keep the clock stable. you can also set the lock to PC time...
Sent: 2/13/2024 9:39:00 PM
Subject: RE: Ultriscape timeofday clock
you can also set the lock to PC time every once and a while.
Mike Pomerleau
Sent: 02-13-2024 20:25
Subject: Ultriscape timeofday clock
Hi Mark,
I have the same problem... The default timeofday clock, runs 65 seconds ahead of the system clock.
I'm running an Ultrix Carbonite - the time of day clock on the switcher MV is correct, but the Ultriscape clock is wrong.
Does the default time of day clock in Ultriscape take it's time from the system clock on the Dashboard PC, or from network time received by Ultrix?
Thoughts?
David Hidden
Senior Technical Operator
Kojo
Sent: 02-13-2024 16:44
Hi Mark,
in your layout editor there is a tab at the top, dedicated to setting the different clocks.
You can also add a differnt clock in the same interface.
Mike Pomerleau
Sent: 02-12-2024 13:17
Whenever I place a timeofday clock in a MV display, it does not match the system time. Is there a place to adjust/reset the time used for the timeofday clock?
Mark Wetstein
