Recently had a Xpoint failure and had to upgrade firmware from 5.x to 6.2. Since the upgrade I lost connection to a soft panel that was access for users on the engineering computer to access to limited levels of routing. This was to limit what access was given instead of full access to BCS. I can not recreate the router soft panel or reconnect it.
Would anyone advise how to create a soft panel to the device database? I have it created in panels I just need to create the connection to a soft panel not physical unit.
Will Martin
