  • 1.  Use Tab button to cycle to next item
    Posted 11-23-2024 16:45
    I have 2 text inputs where an operator needs to be able to input the first value, then immediately put in the next value, but going back to the mouse to select the 2nd text input can cause an operator to miss the moment. I was hoping I would be able to use the tab key to get to the next input and quickly begin inputting information to keep the operators hands constantly on the keyboard. Anyone think they can help?
    Nathaniel Hay
  • 2.  RE: Use Tab button to cycle to next item
    Posted 11-25-2024 15:23
    Hi Nathaniel,
    Yes you can use the tab key on your keyboard if the two text inputs are next to each other and you are not in PanelBuilder edit mode.
    Cheers,
    Aury Rukazana
    Senior Software Developer
  • 3.  RE: Use Tab button to cycle to next item
    Best Answer
    Posted 11-28-2024 10:19
    Hey Nathaniel, stacking order matters for being able to tab between items. So if you want to tab between item 1 and 2 you'll want them back to back in the running order of the panel.
    Mark Macklin
