  • 1.  Xpression Audio Feed + DB Meter
    Posted 03-11-2025 15:51
    Has anyone ever brought an audio feed into Xpression to create a DB Meter? Any direction or help on this would be great.
    Ryan
    Ryan Gonzales
    Sr. Producer and Director
    Kroenke Sports and Entertainment
    Denver
  • 2.  RE: Xpression Audio Feed + DB Meter
    Posted 03-11-2025 16:25
    I have used a solution where I have a dashboard and the operator just reacts live to the audience.
    I do remember one stadium doing it for real but I cannot remember the method, I will try to remember.
  • 3.  RE: Xpression Audio Feed + DB Meter
    Posted 03-11-2025 16:32
    Thanks for the response, Simon!
    If you remember how one stadium did it for real, please let me know.
    Ryan Gonzales
    Denver
  • 4.  RE: Xpression Audio Feed + DB Meter
    Posted 03-12-2025 10:15
    Hello Ryan,
    I have done this with Xpression for some TV-Shows. I doubt, that this would be possible just within Xpression. I used the Xpression SDK within a .net framework programming.
    The issue is, that you need access to a volume analyser. There are some libraries available to do this in .net. Even as it it possible to implement certain libs within Xpression, I believe that those libs could not be linked and even if they were, I gues that you could run into some performance issues,
    Doing this in c# or vb.net is not a big deal. You could try to use some AI to generate code for you. Only the implentation of the xpression.dll might not be found there, but there is no big difference to what you would do in scripting.
    Regards Tom
    Tom Lehmann
    CEO
    IT Services
    Frankfurt/Main Germany
  • 5.  RE: Xpression Audio Feed + DB Meter
    Posted 03-15-2025 05:47
    Hi!
    Alternatively, you can try using TouchDesigner  and transfer the finished video stream via NDI to Xpression.
    Here are examples of how to do it https://www.youtube.com/watch?v=ua4zKWJg22g
    https://www.youtube.com/watch?v=shj4473s96Y
    Roman Yaroshenko
    chief specialist
    RBC-TV
    Moscow Russian Federation
