  • 1.  Xpression Layer Setting with SEQI Command using StreamDeck
    Posted 02-25-2025 15:51
    John Kimball
    Video Production
    Legislative
  • 2.  RE: Xpression Layer Setting with SEQI Command using StreamDeck
    Posted 02-25-2025 16:31
    Is there no TAKE command? In my dashboards I use rosstalk command TAKE eg TAKE 101
  • 3.  RE: Xpression Layer Setting with SEQI Command using StreamDeck
    Posted 02-25-2025 16:50
    I see a TAKE command but it looks like the TAKE(3) command as in a custom control since it has fields for take ID, frame buffer and the layer. So that actually has one more field needed to fill out.  I know there used to be a TAKE(1) command that only needed the takeid field but I don't see that available any longer in rosstalk.
    In Companion, it is the same list as all available commands listed here:
    Sending RossTalk Commands to XPression
    John Kimball
    Video Production
    Legislative
  • 4.  RE: Xpression Layer Setting with SEQI Command using StreamDeck
    Posted 02-25-2025 17:00
    Does it force you to fill those fields in or can you leave them blank?
  • 5.  RE: Xpression Layer Setting with SEQI Command using StreamDeck
    Posted 02-26-2025 14:33
    The buffer and layer fields are also optional in the TAKE command.
  • 6.  RE: Xpression Layer Setting with SEQI Command using StreamDeck
    Posted 02-26-2025 14:32
    Just send SEQI takeid
    The layer value is optional in SEQI
