  • 1.  Xpression Timer Function Block linked to Scene Director
    Posted 09-24-2024 19:36
    I need help linking a countdown Timer to either a "PAUSE" event or a designated time on the Scene Director timeline.  So, the directors of the show can control when the countdown timer starts.  I've tried the VL below.....but it's not working. :( Any ideas?
    SS Blank
    KSL TV5
  • 2.  RE: Xpression Timer Function Block linked to Scene Director
    Posted 09-25-2024 10:13
      |   view attached
    Hello! I was able to get this working with similar visual logic.
     I used a "Greater Than" block, set the base to 10, and placed a pause block at frame 10 on the scene director. Take online to ready it, the scene will wait in a paused state, take again to start the countdown. I have attached a copy of the scene for you to take a look at inside of XPression. File > Import > From Project/File.
    Let me know if this gives you any trouble! There is another solution using very simple scripting and a clock timer widget if this visual logic continues to give you a hard time.
    Brishen Thompson
    Demonstration Artist & Trainer - Generalist
    Attachment(s)
    zip
    Countdown.zip   157 KB 1 version
  • 3.  RE: Xpression Timer Function Block linked to Scene Director
    Posted 09-25-2024 11:16
    Perfect...thanks!  I was so close! I knew I had something setup slightly off!
    SS Blank
    KSL TV5
