  • 1.  Xpression via NDI to vMix
    Posted 09-29-2023 09:49
    Is it possible to connect Xpression via NDI to vMix? If so, which versions of Xpression support NDI with alpha?
    Gian Delgado-Aspiazu
    Rogers TV
  • 2.  RE: Xpression via NDI to vMix
    Ross Staff
    Posted 09-29-2023 09:58
    Any versions that support a physical output also support NDI outputs but it will use up one of your channels so if you have a 3 channel studio it will use one of those.
  • 3.  RE: Xpression via NDI to vMix
    Posted 09-29-2023 10:13
    Thank you so much!
    Rogers
  • 4.  RE: Xpression via NDI to vMix
    Ross Staff
    Posted 10-02-2023 12:26
    NDI Libraries XPression Version Implementation
    XPression v10.7 build 5586 - NDI Library v5.0
    XPression v10.1 build 5417 - NDI Library v4.6
    XPression v9.7 build 5065 - NDI Library v4.1
    XPression v8.7 build 4708 - NDI Library v3.5
    XPression NDI Feature-set
    • Output fill+key (v8.0+)
    • Input fill (v8.0+)
    • Audio 8chs (v8.7+)
    • Input fill+key (v10.1+)
