# VDCP Control
**URL:** <https://rossvideo.community/t/vdcp-control/10320>\
**Category:** Production Switchers\
**Created:** [February 20, 2018, 9:55pm UTC](https://rossvideo.community/t/vdcp-control/10320 "2018-02-20T21:55:00Z")\
**Posts on this page:** 15\
**Page:** 1
<div class="post-metadata">
**Author:** ![dixonstyres](https://rossvideo.community/letter_avatar_proxy/v4/letter/d/f6c823/32.png) [@dixonstyres](https://rossvideo.community/u/dixonstyres)\
**Post date:** [February 20, 2018, 9:55pm UTC](https://rossvideo.community/t/vdcp-control/10320/1 "2018-02-20T21:55:00Z")
</div>
I’ve been looking to play videos on my graphite server channels via VDCP control. What will the ip/port settings be to interface?
**Author:** ![leso\_reilly](https://rossvideo.community/user_avatar/rossvideo.community/leso_reilly/32/159_2.png) [@leso\_reilly](https://rossvideo.community/u/leso_reilly)\
**Post date:** [February 20, 2018, 10:37pm UTC](https://rossvideo.community/t/vdcp-control/10320/2 "2018-02-20T22:37:00Z")
</div>
What is the device that your trying to do the control from?
Your XPression Media Control Gateway has an AMP tab and a VDCP tab. Default port is 9091 for VDCP on XPression. The IP is the IP of the windows system.
[#Graphite](https://livinglive.community/search?s=%23Graphite&executesearch=true)
[#Graphite](https://livinglive.community/search?s=tags%3A%22Graphite%22&executesearch=true)
**Post date:** [February 20, 2018, 11:04pm UTC](https://rossvideo.community/t/vdcp-control/10320/3 "2018-02-20T23:04:00Z")
</div>
Trying to control it from Dashboard. I loaded in the example VDCP panel and looked like i was unable to connect. I’m using Dasboard on another computer though so that may be the issue. I’ll try to integrate it into my created buttons and see.
**Post date:** [February 20, 2018, 11:12pm UTC](https://rossvideo.community/t/vdcp-control/10320/4 "2018-02-20T23:12:00Z")
</div>
Where is the VDCP example panel that you refer to? I will check it out as to why it does not work.
**Post date:** [February 20, 2018, 11:30pm UTC](https://rossvideo.community/t/vdcp-control/10320/5 "2018-02-20T23:30:00Z")
</div>
[https://www.rossvideo.com/control-systems/dashboard/dashboard-u/video-tutorial-108/](https://www.rossvideo.com/control-systems/dashboard/dashboard-u/video-tutorial-108/)
**Post date:** [February 20, 2018, 11:34pm UTC](https://rossvideo.community/t/vdcp-control/10320/6 "2018-02-20T23:34:00Z")
</div>
Also, when you say Windows system, Should i be directing to my public IP address, or the one of the graphite (192.168.0.113)?
**Post date:** [February 20, 2018, 11:49pm UTC](https://rossvideo.community/t/vdcp-control/10320/7 "2018-02-20T23:49:00Z")
</div>
Also, am i going about this the right way? When i used RossTalk to play videos through Xpression they would only play in the frame buffer where as i needed them to play on my server channels.
**Post date:** [February 21, 2018, 12:06am UTC](https://rossvideo.community/t/vdcp-control/10320/8 "2018-02-21T00:06:00Z")
</div>
The Computer that is running DashBoard that needs to send commands to the XPression IP address. So your windows machine had multiple NIC cards. If you have the 192.168.0.113 plugged into a NETWORK and the DashBoard PC is also on that same network then you can use that IP address. If the computer that your trying to run this from is not on the same network as the 192. range then your going to need to point to the other IP address and network that the PC and XPression are on.
I just tested this panel against a unit in the dev lab. It works just fine. I got a clip list and could load to the channels and then sent the play commands. So it works.
**Post date:** [February 21, 2018, 12:33am UTC](https://rossvideo.community/t/vdcp-control/10320/9 "2018-02-21T00:33:00Z")
</div>
Second question about RossTalk – When you make Sequencer Take IDs you would then want to make sure to assign those to Server Channels not Frame Buffers. Then with RossTalk commands when you configure the Panel you have to use the SEQI I Command and only specify the Take ID and leave Channel and Layer set to SEQ selections.
When you use the TAKE Command it always requires that you specify the ID channel and Layer. I will have to talk to the XPression Dev team to see if the server channels will work via the RossTalk Protocol this way. Or if we need to add some functionality. That said I have tried the VDCP App and it just works so I would suggest trying it.
There is also a Purchasable VDCP ShotBox DashBoard Application that also works.
**Post date:** [February 21, 2018, 1:38am UTC](https://rossvideo.community/t/vdcp-control/10320/10 "2018-02-21T01:38:00Z")
</div>
Okay, i switched my commands over to the SEQ and have it working now.
**Author:** ![michaelolsen](https://rossvideo.community/letter_avatar_proxy/v4/letter/m/ea666f/32.png) [@michaelolsen](https://rossvideo.community/u/michaelolsen)\
**Post date:** [December 17, 2018, 5:17pm UTC](https://rossvideo.community/t/vdcp-control/10320/11 "2018-12-17T17:17:00Z")
</div>
a related questions to VDCP, I am also testing Xpression use VDCP to control my clip server, if possible do any one of you know the command for play speed in dashboard???
I my case I hope that i can use it as a light way to do replay.
**Post date:** [December 19, 2018, 4:15am UTC](https://rossvideo.community/t/vdcp-control/10320/12 "2018-12-19T04:15:00Z")
</div>
Currently the VDCP Visual Logic device does not have VARIABLE Play in it. We will look at adding it when we can.
**Post date:** [January 11, 2019, 7:59pm UTC](https://rossvideo.community/t/vdcp-control/10320/13 "2019-01-11T19:59:00Z")
</div>
Thanks, is it then possible to get the duration it to dashboard?? If yes then how ??
**Post date:** [January 11, 2019, 8:33pm UTC](https://rossvideo.community/t/vdcp-control/10320/14 "2019-01-11T20:33:00Z")
</div>
Think your going to be best to visit the DashBoard Forum with that question :). It is getting beyond my usual abilities and into setting up listeners and parsing data 🙂
**Author:** ![michaelblank](https://rossvideo.community/letter_avatar_proxy/v4/letter/m/4af34b/32.png) [@michaelblank](https://rossvideo.community/u/michaelblank)\
**Post date:** [January 11, 2019, 8:36pm UTC](https://rossvideo.community/t/vdcp-control/10320/15 "2019-01-11T20:36:00Z")
</div>
Ok i wil Do that thanks
