Hi James, this thread where I look to get info from a Blackmagic MultiView should help you out: https://rossvideo.community/discussion/dashboard-control-of-blackmagic-multiviewvideohub-via-telnet
The videohub acts very similar to the multiview and you should be able to adapt the same code and method of talking to the videohub. The input labels./output labels and the current routes should all be a part of that preamble, you just need to take the data and put it where you want.
Jake Lew
Access Communications Co-Operative Limited
Regina Canada
Sent: 03-18-2024 07:08
Subject: Blackmagic Video Hub - Display routes
Hello All!
I've just joined a facility that uses Blackmagic videohub routers. I'd like to create a dashboard that displays the route information for each destination. I was wondering if someone would be able to point me in the right direction as I have no idea where to start!
James Forshaw
