Ah yes I understand. My Graphite is one of the first generations from back when they were first released. 2018 if I recall correctly. Last updates were in 2019... I am honestly afraid to do updates to the machine as to not cause a total failure of the box.
Thankd for your response! Perhaps this is just a feature we'll have to live without until we invest in a newer system!
Matthew Cordero
Na Leo TV
United States
Sent: 02-28-2024 01:27
Subject: Custom Control Event to change ME Selected on Carbonite Panel
Hi Matthew,
Yes, it is available on Graphite. But the Graphite needs to be running the latest v6.2 firmware.
If your Graphite is not on v6.2, please contact tech support (techsupport@rossvideo.com or https://support.rossvideo.com/hc/en-us). They will guide you through the upgrade process, as the XPression side may be required to be upgraded as well to be compatible.
Aaron
Sent: 02-28-2024 00:43
Thank you Aaron! I have a Graphite Frame. Do you know off hand if that is available on the Graphite?
Thank you so much!
Matthew Cordero
Na Leo TV
United States
Sent: 02-28-2024 00:35
Hi Matthew,
May I know which frame are you using? If you are using a Carbonite Ultra or newer frames, there is a "Row ME Assignment" event that you can insert in a Custom Control. I have attached a screenshot of the event.
Aaron
Sent: 02-26-2024 16:42
Hello! I am wondering if it is possible to set a Custom Control event to change the Carbonite CB2s Panel's ME1 Delegation to another ME. For example. When running a Custom Control that will be taking Mini ME1 online, I could add a CC event that also presses the Mini ME1 select on the panel so I can see Mini ME1 on my Top ME row on the CB2s?
Any help or suggestions are appreciated!
Matthew Cordero
Na Leo TV
