Ok,understood.
However,regarding the outputs which are not being converted, os it possible to use delay longer than 1 frame?
If so, how can I do this?
Thanks,
João victhor Mariano
Sent: 03-18-2024 15:25
Subject: CustomPanel - Crosspoints with frame delay.
You can not Delay the output of the switcher on the down covert longer than a single frame. There is no Delay function on an output converter.
Sent: 03-15-2024 15:23
I currently have a Carbonite Ultra switcher running at 4k video mode. I have 3 video sources (CAM1,CAM2,CAM3) that enter the switcher in 1080i format. As the switcher converts them, I'm able to display them in 4K on the Multiviewer.
However, a client asked me to create the following setup:
- Have a PGM output in 4K, and another output (also PGM), but in 1080i. This first "mission" was easy to complete, just using the output FC Assignment.
- Now, the second requirement is that when I have CAM1, for example, in PGM, the 1080i output is streamed with 7 frames of delay in relation to the PGM output in 4k (which will also be with CAM1). I am having difficulty executing this requirement.
Could you help me with this? How I can customizing a panel on the Dashboard to perform this task?
Thanks,
