Josh,
Yes you can. See the example below. I created a string param in dashboard to feed my XPression scene.
Link the param to a text object in XPression. Make sure "Requery Scene Datalinqs" is checkmarked on this text object.
In each of the subsequent stat fields you can then reference the text object linked to dashboard in a text macro (@TextObject@) to filter the path in your data source.
Matt Zidik
Art Director
Sent: 04-29-2024 14:31
Subject: dashboard - playout lower 3rd via Jersey key in xpression
For our baseball profile, I was looking to use one scene for player batting lowers. is it possible for a parameter value coming from dashboard to serve as a jersey key to read rows for batting stats?
Thanks,
Josh
JOSHUA KEAGY
Xpression operator
Blue Ridge 11
