  • 1.  My text not going behind mask in crawl
    Posted 27 days ago
    my text is not going behind my mask in crawl. Still shots are below to see how i set everything up. I've done mask before so i don't get what i'm missing.
    thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 2.  RE: My text not going behind mask in crawl
    Ross Staff
    Posted 27 days ago
    You can't use layer objects because it only blends everything in that scene.
    Remove it from the layer object, it will appear black.
    Make sure its in front of the text on Z space as well.
  • 3.  RE: My text not going behind mask in crawl
    Posted 26 days ago
    I got it to work using scene director. i made a new scene, added a mask and added key frames to the test and it worked that way. i'll check out the z space when i have more time to learn that way as well. thanks
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
