  • 1.  Query Carbonite information from Dashboard
    Posted 04-10-2024 14:17
    I am trying to get the current source on the program bus of a Carbonite from Dashboard.
    Which ogscript command should I use?
    I tried to add Carbonite as a Data Source in the Edit Component, but I don´t know if I also need to add as Device.
    I hope you can help me.
    Regards,
    Eduardo
    Eduardo Mayone
  • 2.  RE: Query Carbonite information from Dashboard
    Ross Staff
    Posted 25 days ago
    Hi Eduardo,
    You can set your carbonite as the data source of your panel and view the available parameters of the device.
    If the source is available as a parameter, you can use params.getValue(oid, Index) to get source. Please find images below on how to view the available parameters.
    Setting the data source:
    To view the parameters, Select Params then select default. Drag a box on the panel and parameters will be display. You can search the source and the oid will be show in parentheses.
    Thank you,
    Aury R.
    Aury Rukazana
    Senior Software Developer
