Hi Jake
Here is an example panel that does this. You're on the right track with getFile - argument passed-in can be either a file or a directory. To get an array of the Files inside of a directory, call getFile with the directory path and use list() on the returned object. Here is an example panel that exercises the feature:
<abs contexttype="opengear">
<meta>
<params>
<param access="1" maxlength="0" name="Starting Directory" oid="Starting_Directory" type="STRING" value="C:\" widget="text"/>
<param access="1" constrainttype="STRING_CHOICE" maxlength="0" name="File List" oid="File_List" type="STRING" value=" " widget="combo">
<constraint/>
</param>
<param access="1" maxlength="0" name="File Extension" oid="extension" type="STRING" value="*" widget="default"/>
</params>
</meta>
<label height="40" left="20" name="Starting Directory: " style="txt-align:east" top="20" width="160"/>
<param expand="true" height="40" left="180" oid="Starting_Directory" top="20" width="380"/>
<label height="40" left="20" name="File Extension: " style="txt-align:east;" top="70" width="160"/>
<param expand="true" height="40" left="180" oid="extension" showlabel="false" top="70" width="160"/>
<label height="40" left="20" name="File List: " style="txt-align:east" top="120" width="160"/>
<param expand="true" height="40" left="180" oid="File_List" showlabel="false" top="120" width="380"/>
<button buttontype="push" height="40" left="580" name="Load" top="20" width="100">
<task tasktype="ogscript">var file = ogscript.getFile(params.getValue('Starting_Directory', 0));
if (file != null && file.exists() && file.isDirectory())
var filter = params.getValue('extension', 0).trim(); //this would be optional
var list = file.list();
var filteredList = [];
for (var i = 0; i < list.length; i++)
if (filter == '*' || list[i].toLowerCase().endsWith(filter)) //Check the filter
filteredList.push(list[i]);
if (filteredList.length == 0) //Put a blank if we have no files that match the filter
filteredList.push("");
var constraint = params.createStringChoiceConstraint(filteredList);
if (constraint != null)
params.replaceConstraint('File_List', constraint);
}</task>
</button>
The relevant snippet is this:
James Peltzer
Sent: 01-24-2024 10:49
Subject: Reading the filenames of every file in a directory
I am looking to use Dashboard code to look at a directory and read all the filenames in the directory. The idea is to have a folder of images that can be dropped in, and Dashboard would be able to read each filename to then send back to XPression as a material for a rotating slideshow.
I know I can verify a specific file using "ogscript.getFile(filepath)" but I am looking for a way to not just verify a specific file, but to look at the folder itself and give me back what files are in there.
Any help would be appreciated.
Jake Lew
Access Communications Co-Operative Limited
