  • 1.  Rename Base Object from Script
    Posted 04-17-2024 13:33
    Is it possible to rename a Base Object (in my case a group object) from a script? I can't seem to find a reference in the API and the .Name property seems to be read only.
    Carlito Chippy
  • 2.  RE: Rename Base Object from Script
    Posted 04-17-2024 14:41
    Yes you can rename it. The 'Name' property is Read-Write.
    XPression API Reference
    Name Property
    See Also  Send comments on this topic.
    xpBaseObject Object : Name Property
    Glossary Item Box
    Description
    Gets and sets the name of the object.
    Property type
    Read-write property
    Syntax
    Visual Basic
    Public Property Name As String
    See Also
    Azathoth
    Son of Cthulhu
  • 3.  RE: Rename Base Object from Script
    Posted 04-17-2024 15:09
    Thanks Azathoth. I actually had seen this and it kept freezing Xpression, but I realised why, I was trying to rename it while it was still an active reference, so I just need to build my scene a bit differently.
    Carlito Chippy
