Humm. I didn't see that. I don't recall where I was in the commands, but it went no further for me. I'll see what I did differently tomorrow. I'm curious if I took a different path. In any case, the Record function works well.
BTW, on a different note, sometimes the "smartphone" touch panel on the ME P/P panel, where you would slide to choose the DVE wipe, does the slide, but sometimes it doesn't. Not a big deal, but I've been meaning to mention it.
Sent: 02-19-2024 15:22
Subject: Specific DVE wipe in CC
I see 25 options in the CC Menu and in the DVE Live Assist Selection Menu?
Sent: 02-19-2024 14:39
Yes, but each wipe doesn't seem to have a command.
Sent: 02-16-2024 15:54
It does have a specific command for this.
Under Switcher - Transition - DVE Wipe Effect
Sent: 02-16-2024 13:15
Ah! The "watch me" Record mode. Of course! The way to have CC do everything you want even when there is not a specific command for it. I'll remember that for other things I'm sure I'll want to do.
Thanks Les.
Sent: 02-15-2024 19:44
Hi Danny,
Yes you should be able to specify the DVE transition you would like.
When building your CC in Record mode you could change to a different Wipe if the correct one is already loaded .. then switch back to the Correct one to get the entry like below in your CC
Sent: 02-15-2024 19:32
Is there a way to program a specific DVE wipe in a CC?
Details:
I have a CC that loads a specific Media Manager GFX then does a hold. On second press, the GFX channel is put in PST, the DSK transition speed is changed from 20 to 60 frames, the transition is changed to DVE, the DVE move executes, the CC pauses to allow the effect to execute and then normals the transition panel back to 20 frames and a dissolve. Custom Controls are quite useful.
It seems an R State recall (STORE-ALL) resets the DVE to a different move. I'd like the CC to recall the DVE move I prefer for this specific effect.
Hardware:
ME P/P Transition panel, TD2/Carbonite Ultra.
