  • 1.  Virtual output question
    Posted 25 days ago
    Hi All,
    I'm wondering if there's a way to make the size of the virtual outputs use it's entire window. There's so much white space that could be used (see screen shot) and it seems like a waste. I see that it's a 1920x1080 resolution but can it be zoomed in through a setting that I haven't found? I don't want to change my monitors scale or resolution and I don't think that would fix the 'issue' anyways. Thanks in advance...
    Screen shot of CG1 virtual output
    Donny Swanson
    Graphic Designer, Broadcast
    TVO (TVOntario)
    Toronto Canada
  • 2.  RE: Virtual output question
    Posted 24 days ago
    There are two ways to make a Virtual Output fullscreen.
    When you create one, there is the option to check the "FullScreen" tickbox:
    When you already have a Virtual Output, you can right-click in it to make it fullscreen:
    Rob van Rooyen
    Senior Graphics Specialis
    NEP The Netherlands
    Hilversum Netherlands
  • 3.  RE: Virtual output question
    Posted 24 days ago
    I believe this is version centric.
    We are currently on 9.5 and our Virtual Output Settings only has
    • Show On Startup
    • Stay On Top
    • Automatically Adjust Aspect Ratio
    Right clicking on the Virtual output does have the option for Full Screen, but it is grayed out and cannot be selected.
    What a tease.
    Azathoth
    Son of Cthulhu
  • 4.  RE: Virtual output question
    Posted 24 days ago
    I'm on version 11. I have the 'right click' option but as Azathoth pointed out, it's greyed out. What I want is to fill the entire window and not have all that white space
    Donny Swanson
    TVO (TVOntario)
    Toronto Canada
  • 5.  RE: Virtual output question
    Ross Staff
    Posted 24 days ago
    In XPression Designer & Developer, full screen virtual outputs are not supported.
    You need to upgrade to XPression Studio, BlueBox or Prime for full screen virtual outputs.
  • 6.  RE: Virtual output question
    Posted 23 days ago
    Grayed out option.
    Total dick tease.
    Azathoth
    Son of Cthulhu
