Xpression Crawl Glitch in Logo
  • 1.  Xpression Crawl Glitch in Logo
    Posted 04-15-2024 13:11
    I created a crawl in xpression. i have the text datalinq to a microsoft exel sheet. i'm using the N method. Also i have in each scene a visual logic which is...if text 1 is empty no logo visible.
    Everything works fine but when i don't have any text in text 1 for my first scene and i play the scene i get a glitch . i see my logo appear then disappear as the crawl reads the 2nd scene. any ideas? thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 2.  RE: Xpression Crawl Glitch in Logo
    Posted 04-15-2024 14:17
      |   view attached
    i posted the video below of what its doing.
    thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 3.  RE: Xpression Crawl Glitch in Logo
    Ross Staff
    Posted 04-16-2024 06:24
    Use an onOnline script to hide the logo instead of visual logic.
    dim text as xpTextObject
    dim logo as xpBaseObject
    self.GetObjectByName("Text1", text)
    self.GetObjectByName("Logo1", logo)
    if text.Text = ""
    logo.Visible = false
    else
    logo.Visible = true
    end if
  • 4.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 06:41
    Thank you.  I will try this when I get to work
  • 5.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 14:47
    Do I type this in its own line in the script editor?
  • 6.  RE: Xpression Crawl Glitch in Logo
    Ross Staff
    Posted 04-16-2024 19:15
    Needs to go in onOnline.
  • 7.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 21:41
    Yes I know that but do I put it all together or alin separrr lines when I type it
  • 8.  RE: Xpression Crawl Glitch in Logo
    Ross Staff
    Posted 04-17-2024 05:09
    As it's written.
  • 9.  RE: Xpression Crawl Glitch in Logo
    Posted 30 days ago
    i typed it in as you wrote it and nothing. i typed it in Online.i still get the glitch of the logo. i think our xpression is having issues. it works well sometimes then goes bad playing the glitch. it never did that before. i did another exel sheet thinking maybe the old one was corrupt and it worked fine then started glicthing again.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 10.  RE: Xpression Crawl Glitch in Logo
    Posted 29 days ago
    If you haven't already, could you try, in the Scene Manager, to turn off that logo object (the "eyeball") ?  That way it only is made visible once, when the script (or your previous visual logic) runs.
    Paul
  • 11.  RE: Xpression Crawl Glitch in Logo
    Posted 29 days ago
    I'll try I check it on Monday  and see. I will let you know. Thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 12.  RE: Xpression Crawl Glitch in Logo
    Ross Staff
    Posted 29 days ago
    Do you know how to script and debug and use debug monitor?
    Because you need to take the example script I gave you and adjust it for your scene, like what are your scene objects called and things like that.
