  • 1.  XPression Preview Window
    Posted 03-27-2024 14:19
      |   view attached
    I am having an issue seeing what I am working on in xpression. We used to be able to see the specific graphic/scene in a window in xpression. Now, the windo is blank, therefore, we cannot see real to changes we are making to a particular scene/graphic. Picture below shows our xpression layout.
    Andre Sanders
    Technical Media Producer
    WUFT
  • 2.  RE: XPression Preview Window
    Ross Staff
    Posted 03-27-2024 14:31
    Probably one of two things (or both).
    Do you have a monitor or display emulator connected to the Graphics card on the XPression hardware? There must be at least one active EDID on the graphics card for it to function correctly for XPression.
    Do you have the graphics card selected in XPression? (you need the above first before you can set this correctly).
    XPression > Edit > Preferences > Hardware Renderer > Adapter > Select the NVIDIA GPU
    Judging by your screen shot, you're using VNC, so I bet you have no display connected to the XPression hardware. If you want to run it headless, get an emulator like this:
    https://www.amazon.ca/BUYMINERS-CA-HDMI-Dummy-Plug-3840x2160/dp/B07FB8GJ1Z
