Camera Motion Systems
  • 1.  Recall speed
    Posted 10-11-2017 21:11
    Is there a way to change the recall speed? What I would like to do it set one shot as a wide and another as a tight and have the camera do a nice slow zoom in. I can do the zoom manually but I need to be able to do it using overdrive and custom controls.
  • 2.  RE: Recall speed
    Posted 12-24-2017 12:08
    Sorry for the late reply on this one. Yes you can control recall speed under the dashboard camera camera config page. However PivotCam is not designed for on-air moves, if all you are recalling are zoom positions it might work but not if any other positional parameters are changed.
    #PIVOTCam
