I have installed new PivotCam-SE's, and they were working fine for a day. I added control on Dashboard, and they had connectivity, and were able to be controlled. I tried adding them to my Carbonite Black Plus to control from there as well, and they are now all disconnected. I have tried re-inputting the camera in Dashboard (after deleting the connection on my Carbonite), deleting the cameras on Dashboard completely and re-installing it, and then deleting everything and trying to only control it on the Carbonite.
Has anyone run into an issue? I also was able to see on the "Preview" tab on the actual IP address, but then I started losing control and I can still log in and move the camera from the IP address, but I can't see anything on the preview screen.
