Infrastructure​
  • 1.  MC1 GPI WITH VIZRT
    Posted 02-05-2014 16:01
    we are using MC-1 Master Control Switcher and want to configure its GPI/O with Vizrt, Can we connect and if yes what will be the procedure to connect the same
    Atul Garg
  • 2.  RE: MC1 GPI WITH VIZRT
    Posted 02-14-2014 14:40
    Hi Atul,
    The MC1 has 8 GPI/O on the Card Rear Module, which can be set to either trigger on edge, high, or low level GPI/O. What function are you looking to trigger from GPI?
    // Chris
    #openGear
  • 3.  RE: MC1 GPI WITH VIZRT
    Posted 02-15-2014 13:31
    Hi Chris,
    we want to use MC1 Squeeze effect with Viz-rt Ticker Engine only, Please Provide the Solution.
    Atul Garg
    #openGear
  • 4.  RE: MC1 GPI WITH VIZRT
    Posted 02-19-2014 18:12
    Hi Atul,
    MC1 Can receive the command for Squeeze in one of several ways. First is via Manual control from the Dashboard UI, second is via GPI, as previously mentioned, and third is via presmaster automation command, which can received either from the serial port, or over IP.
    You can contact me direct at cwelsh@rossvideo.com, and we can take a look and find the best way to implement this.
    Chris
    #openGear
  • 5.  RE: MC1 GPI WITH VIZRT
    Posted 01-23-2015 11:04
    Hi Atul
    Did you find the solution of connecting mc1 GPI with viz. If yes please help me to do this.
    sandip
    #openGear
