This reply probably comes far too late, apologies. When you perform hot punching on an MC1, in order to perform a clean audio transition, the PVW bus is used. The new source is temporarily placed on PVW, then a transition is performed (for clean audio), and finally the PVW is set back to its original source.
#MasterControl
