Infrastructure​
  • 1.  UDC-8625A question
    Posted 05-26-2015 15:54
    Question:I have 2 UDC-8625A cards and I have HD SDI inputs that I just need to gen lock to the system, no conversion.
    How many individual inputs can I use with discrete outputs for each one?
    Is this possible or should I just get a frame sync card?
  • 2.  RE: UDC-8625A question
    Posted 05-27-2015 14:09
    Hi Dave,
    The UDC-8625A has 4 HD-SDI inputs, but only will process one at a time. The additional inputs provide provision for switching, mixing and keying. So, you will need one UDC for each HD-SDI source in this case.
    For simple synchronization without conversion, our SFS-8622-A is a lower-cost frame synchronizer card for the openGear frame. Again, it is one channel per card.
    Cheers,
    Alun
    Alun Fryer
    Marketing Product Manager, Techincal – Infrastructure.
    #openGear
