Hi Adrian,
The MC1 currently only supports Ross NK router matrix. If you have a way to convert protocols, it might be possible to control another one. DashBoard could be used, though I would not recommend it, because latency cannot be guaranteed. If you have a specific router you'd like supported, please let our marketing folks know.
Voiceover is supported on SDI embedded audio, if you want external AES, we normally bundle use a MUX-8252 to embed the audio before it enters the MC-1, this works transparently. If a single-card solution is important for you, once again please let our marketing folks know, as they can make it happen (if there is sufficient interest).
Cheers,
Ralph
#openGear
