Hi Jacob,
yes, it was not so easy to reverse-engineer this protocol. - As you see, unfortunately the Ultrix-support is denying any information regarding the syntax. - I'm actually not sure if they even know this word...
Where I found mutch better help was from "sam - Snell Advanced Media". - If you look for them in relation with "probel" you will find a very good manual.
Be aware, that the manual starts with the protocol SW-P-02, what you will not need. - What you need is the SW-P-08, starting at page 16.
The very short summery of the syntax is as follows:
Message: 10 02 DATA BTC CHK 10 03
Data: Command (02) Matrix+Level (00) Multiplier (00) Destination-1 Source-1
BTC: Byte-Count of Data
CHK: not (Data + BTC) +1
And now the freaky part:
If you need the value of x10 (ASCII for Linefeed), either in Data, BTC or CHK, you have to substitute the value with a double-byte: x10x10....
I hope this helps,
regards
Martin
#Ultrix
