Connectivity
  • 1.  NK-GPI output design
    Posted 10-26-2012 21:19
    According to the manual, the GPI outputs are active low; the illustration shows a load of an LED and resistor being pulled to ground.
    The issue is this: I need to combine several tally outputs to indicate when a particular source is switched to either of two destinations. How the GPI output circuit is designed will determine how easily I can make this happen:
    - If the GPI outputs are either open-collector (through a driver like a ULN2803, for instance) or relay contacts, I can merely connect the outputs together and achieve a wired-or result;
    - If the GPI outputs are bipolar -- that is, they try to assert a logic high when inactive -- then I need to use switching diodes to produce the 'or' function.
    Can you shed some light on what the output circuit looks like?
    -- Jeff
  • 2.  RE: NK-GPI output design
    Posted 10-29-2012 11:22
    Hi Jeff,
    The ouputs on the NK-GPI are open collector, through a quad opto-coupler. There are no current limiting resistors, and the maximum collector current that the optocoupler can handle is 50mA per channel.
    If you need further details, please let us know.
    Regards,
    -Ralph
    #NK
  • 3.  RE: NK-GPI output design
    Posted 10-29-2012 12:24
    Ahhh... sounds like you're using something like the TLP504A-2's that I build into most of my interfaces. That's exactly what I was hoping to hear. Thanks for the information!
    -- Jeff
    #NK
