Connectivity
  • 1.  Importing NK Router Global Labels into Dashboard Switchboard.
    Posted 10-05-2012 17:33
    I just downloaded Dashboard 5.1 It's nice that you can control the NK Router through Dashboard. Is there a way to import my Global labels into the switchboard? Or do i have to type them in? My router was configured using Phoenix.
    Stan Kertesz
  • 2.  RE: Importing NK Router Global Labels into Dashboard Switchboard.
    Posted 10-05-2012 17:56
    Hi Stan,
    You can use the same global label configuration file that you used with Phoenix. The easiest way is to use the File Navigator, and point it to the directory where all your existing .CBD and .LBL files are located. Then it is just a matter of double-clicking your existing global label file to load into Dashboard.
    Regards,
    -Ralph
    #NK
  • 3.  RE: Importing NK Router Global Labels into Dashboard Switchboard.
    Posted 10-05-2012 18:29
    Great. Thanks. Worked like a charm.
    #NK
