Connectivity
  • 1.  NK-GPI with Ultrix
    Posted 01-17-2016 22:46
    I want to use the NK-GPI to control a crosspoint for the Engineering station in a new studio... is this possible, and what other components are needed to make this happen?
  • 2.  RE: NK-GPI with Ultrix
    Posted 01-18-2017 02:36
    Hi
    In order to use the NK-GPI with Ultrix, you will need to add the UltricoreCC System controller to the system. It has onboard T-Bus ports for connecting the GPI to the Ultrix system.
    Chris
    #Ultrix
  • 3.  RE: NK-GPI with Ultrix
    Posted 06-06-2017 08:22
    Can you use the combination NK-GPI and Ultricore to generate tally on the Multiviewer, when tally information coming from the video switcher is only available as GPI out ?
    #Ultrix
