Hi.
We're upgrading our old Talia EOS system to the following bits:
NK-IPS
NK-VRC
NK-3G34
NK-D16-75
RCP-NKM x 5
NK-JBX (to use old RCPs)
Using the latest dashboard, was able to get my head around most of it, but not sure if the NK-VRC has to sit in the T-BUS network in a particular spot. The examples I've found, (such as
http://www.rossvideo.com/images/routers/diagrams/nk-ips-vrc_header.jpg) show it inbetween a RCP and the IPS. Does it need to be inline, or can it sit anywhere, ideally I'd run all my devices straight from the IPS 8x T-Bus outputs.
I ask because I'm getting "No Response" errors from the RCPs when trying to switch, running them in Virtual Routing enabled.
The Dashboard Switchboard works in Virtual Mode, and I can see the routing changes, update on the RCP panel display. And the RCP works fine if it's doesn't have Virtual Routing enabled.
The NK-VRC has the "B" LED on permanently, implying it hasn't got a response from the physical router perhaps?
The NK-IPS doesn't have any option to tell it about Virtual Routing does it?
Anyway thought I'd ask here, in case the T-Bus cabling/location for the VRC makes a difference or if there's advice.. otherwise I'll keep trying.. and liking the dashboard software better than the old Geneos I'm used to.
Simon
