Hi Lee,
I'm not able to share RP 168 unfortuantely. But I can tell you it lists different values for almost every video format. And this just defines where the switching line and switching point should fall. Each piece of video equipment interprets this somewhat differently.
The NK-3G routers perform what is often called a "timed switch". Based on the reference signal, the router cuts the video signal at the exact switching point as defined in the SMPTE spec. As there is only one reference, the router cuts
all signals at this same point. If all inputs are the same video format, and they are timed perfectly, then the output from the router will also be clean -- downstream devices will not be able to tell.
But in practise, there is always some variation in timing. Thus the individual video signals will be cut "near" to the switching point, but not exactly. It is now a question of whether downstream equipment can handle such a mis-timed switch. Some devices will not tolerate even a minor (one pixel) shift. Others, like our MUX/DMX cards, are designed to handle +/- ½ line variation. There really is no single standard value here -- RP 168 is a recommendation, but not a hard requirement.
Depending on your needs, you might need to consider using either a line-sync or a frame-sync (possibly with clean audio switching) downstream of the router. It really depends what you are feeding into. Studio monitors tend to be quite sensitive, while many other downstream devices are more forgiving. Also if you are using some sort of SDI to HDMI conversion to drive your monitor, consider its specifcations as well.
Regards,
-Ralph
#NK
