Connectivity
  • 1.  Make crosspoint with one buton
    Posted 01-09-2014 12:40
    We want to use one rcp-nk1 as a panel for the shading.
    They want to switch the monitor with one push on a button instead of choose the source and press take.
    Can this be done without the take command?
    Greetings Gerrit
    RTV Drenthe
  • 2.  RE: Make crosspoint with one buton
    Posted 01-09-2014 12:51
    Hi Gerrit,
    Yes, the button can be configured as a CROSSPOINT type, rather than SOURCE or DEST.
    For details, please see pages 59 and 60 in the NK router manual:
    http://www.rossvideo.com/pdf/manuals/routing-systems/nk_series_user_guide.pdf
    or feel free to contact our tech support team if you need assistance.
    Regards,
    -Ralph
    #NK
  • 3.  RE: Make crosspoint with one buton
    Posted 01-09-2014 14:30
    Ok, but then i still need to push the take button.
    Is it possible to do this without take?
    Greetings
    Gerrit
    #NK
  • 4.  RE: Make crosspoint with one buton
    Posted 01-09-2014 15:26
    When you have a Take button, then the panel will wait until you press it.
    However, if there is no Take button, then the Crosspoint will be sent immediately.
    So, remove the Take button from your NK1 configuration, and it should work with a single push.
    -Ralph
    #NK
  • 5.  RE: Make crosspoint with one buton
    Posted 01-09-2014 15:41
    Yes this is the solution
    Thanks very much.
    #NK
  • 6.  RE: Make crosspoint with one buton
    Posted 01-10-2014 13:55
    Is it possible to have the button still light up when configured this way? It's very irritating to lose the backlight and not be able to see which one is selected.
    -David
    #NK
  • 7.  RE: Make crosspoint with one buton
    Posted 01-10-2014 14:05
    Yes david that's a good one
    #NK
  • 8.  RE: Make crosspoint with one buton
    Posted 01-10-2014 15:58
    The button will light up whenever the crosspoint is active. After you press the button, it should remain lit, until another switch (for the same destination, but with a different source) occurs.
    #NK
