I am integrating a new NK router and would like to have the following set up:
3 independent RCP-NKM router heads
1 Computer interface control
The router shipped with a T-bus to Ethernet "adapter" which I don't see referenced in any of the set up documentation. Can I use this to break out to an independent switch and put a computer running Dashboard on the same network?
