Hi Kevin,
They need to be loaded manually into SwitchBoard:
- In Switchboard, click on the gear wheel icon (upper right corner)
- In the "Configure IPS" dialog, click on the "Labels" button
- In the "Edit Labels" dialog, click on "Inputs", then click on "Import Global Labels"
- Do the same for the Outputs
- Click "OK" to dismiss the pop-ups.
To transfer the labels to a new computer, you can copy the global labels file (look for a *.LBL file in your C:\DashBoard directory) to your new PC, and import it. The simplest way is using the File Navigator window.
#NK
