Connectivity
  • 1.  Saving Router Outputs - NK 3G34
    Posted 06-23-2013 19:45
    We are using a NK-3G34 in a truck and trying to figure out how to save the router settings without using the NK-IPS.
    Every time we power down the truck we have to reassign the router outputs.
    THANKS
  • 2.  RE: Saving Router Outputs - NK 3G34
    Posted 06-24-2013 14:01
    Delano,
    Can you tell me the software version of the Router. There is a fix for that issue in the latest software release.
    You can email me at bcummins@rossvideo.com and I'll get you the firmware.
    Ben
    #NK
  • 3.  RE: Saving Router Outputs - NK 3G34
    Posted 08-08-2018 18:06
    What is the method to save the router settings? Same issue in an OB Truck that we have to reassign the router upon start-up every event.
    #NK
  • 4.  RE: Saving Router Outputs - NK 3G34
    Posted 09-06-2018 13:47
    Hi Nick,
    We had the same issue with a 3G72. After the firmware fix from Ross we still had issues, and had to replace a controller board as well. I would suggest you email Ross support in the first instance to get the firmware fix.
    While we were working on getting this solved I wrote a dashboard script that allowed you to snapshot the matrix in different states and restore them as required, which you might want to investigate.
    https://discussions.rossvideo.com/forum/default-forum-gc1/dashboard-gc43/12492-using-dashboard-to-perform-nk-router-snapshots
    #NK
