Connectivity
  • 1.  Audio Proc Amps in custom Dashboard Panel-
    Posted 12-20-2019 20:08
    I'm looking to create a custom Dashboard panel to adjust the audio gain and delay on a few embedded audio channels coming into my Ultrix.  I'm basically looking to adjust Channel 1 of the first 12 inputs.  I see where I can do this in the Port Configuration, but I've been unsuccessful at breaking those parameters away into a custom panel.
    Does anyone have details on which parameters I'm looking for?  Thanks!
  • 2.  RE: Audio Proc Amps in custom Dashboard Panel-
    Posted 12-20-2019 22:11
    to modify the first audio channel on the first input in the first slot you are looking for this parameter.
    params.frameslots.0.ports.16.signals.1.channels.0.gain
    the second input first channel looks like this
    params.frameslots.0.ports.17.signals.1.channels.0.gain
    Notice that the Slot number starts at 0 and the port starts at 16 (first input). If you are looking to change audio on the output instead it would be as follows.
    params.frameslots.0.ports.0.signals.1.channels.0.gain
    If you want to change the audio delay on the first input in the first slot you are looking for this parameter.
    params.frameslots.0.ports.16.signals.1.channels.0.delay
    You need to have the an Ultrisync license enabled on the input to be able to use this parameter.
    Hope this helps!
    Mike
    #Ultrix
