Hi Ryan,
You can't add multiple audio channels to the same level however you can perform multi level routes with the Ultrix
For example you can create a source or destination called MADI 1 and assign the audio channels to the levels that you need. If we say that source MADI 1 is audio channels 1,2,3,4,5,6,7,8 you add all of the channels to the same source definition.
that way any time to select this source you take all audio channels.
You can create as many source with different iterations as you need. You can even re-use the MADI inputs as much as you want.
You can also do the same with audio destinations however once an output has been defined it cannot be reused.
Hope this helps!
#Ultrix
