Connectivity
  • 1.  Ultrix Layout Edit
    Posted 05-18-2020 20:20
    We are trying to build a new MV and we are encountering an error. After we build it in the Layout Editor, we go into Head Selection and its gray and when you hover over it, it says "WARNING: This layout is incompatible with the frame's active PiP sizes". I've done some searching and can not find any info about this. We are trying to build a simple 3x2 that is left justified, I've attached the picture to show you what we are trying to make happen.
  • 2.  RE: Ultrix Layout Edit
    Posted 05-18-2020 20:22
    Looks like your system is setup to use 1/4 and 1/2 pip sizes. When it comes to the third size, you can only have 1 pip of the C size.
    #Ultrix
  • 3.  RE: Ultrix Layout Edit
    Posted 05-18-2020 20:30
    This is the only layout that is using 1/3 PiP sizes and it set as PiP A in that specific layout.
    #Ultrix
  • 4.  RE: Ultrix Layout Edit
    Posted 05-18-2020 20:40
    Pip A and B need to match what’s selected on the configuration page. C can be whatever size is available but you’re only able to have one pip of the C size in a layout.
    #Ultrix
  • 5.  RE: Ultrix Layout Edit
    Posted 05-18-2020 20:43
    Oh, I see what you are saying now. Thanks!
    #Ultrix
